Stock LS1 nitrous help
Old 05-10-2012, 09:22 AM
JakeyLS1's Avatar
Default Stock LS1 nitrous help
Whats a good set up for a stock ls1? I think i'll only be doing a 100 shot for now but i dont wanna break anything and i want it to be reliable, any thoughts?
Old 05-10-2012, 09:33 AM
Neal@NitrousOutlet's Avatar
on a 100 you will be good with nozzle or plate. Its up to you on what setup you like more. You can get into a nozzle setup cheaper than a plate but the plate usually looks a little cleaner installed because you do not have to drill a hole for the nozzle. Like always, to be safe change out you spark plugs to some br7's since you have a stock ls1, window switch is always a good idea for safety and fuel pressure safety switch. All the little accessories will always help with nitrous being safer.
Old 05-10-2012, 09:36 AM
JakeyLS1's Avatar
Wet or dry shot, what would you recommend for a stock motor?
