Are dished pistons OK for nitrous? Optimal? Not optimal?
I'm probably going to be buying a forged shortblock that is already assembled for the most part, and it has dished pistons. I do have a nitrous kit and was wondering how dished pistons would affect the nitrous?
The Bull
The piston itself will not totally help or harm the use of nitrous. It's mostly based on a couple factors. The first being total compression ratio. A motor at 13:1 plus will make the most significant gains on nitrous. Whereas a motor at 8.5:1 will work but just not as effective. You may not notice a substantial gain. For most of us with flat tops we are hovering around 11:1, which is a pretty good ratio for nitrous on a street car. A lot of this is really based on volume. Obviously with a dished piston you need a little more volume which really takes some power away at each jet size.
The second major factor is the flame front. If it's a true dish piston the flame front should be pretty close to that of a flat top. Guys with big dome pistons sometimes have them dimpled to change the flame front to get a little more even loading on the piston surface. Leads to more effecient horsepower gains from what I can gather.
So the net net of it all is no the dishes will not cause a problem, you just won't see the same gains as someone with a higher compression ratio.
