stock ss wanting nitrous
As the title says I have a bone stock 00 ss m6. I'm wanting to add a 100-125 wet shot. Besides step colder plugs, and timing is there anything else I need. I tried looking but most people have bolts on so that doesn't really help me
You are going to be ok running it on a stock car. Just remember to change out spark plugs to br series plugs, and pull some timing according to jetting. Make sure if your car has some milage on it to make sure your car is tuned up good. (fuel filter, sensors, etc) is always good.
It would be in your best interest to get a window switch since your an m6, purge,bottle heater, and if you have the money pick up a wideband. When my car was m6 I ran 12.30 full bolt ons and 11.78 on a 100 shot with a bad 60' and slipping clutch. I would go through nitrous outlet they can set you up with all that is needed. I don't use their product because it was available in the deal I worked out for my system, but they are some top notch guys and would have used them if I could have. Hope this helps
Yeah depending on what company you go with there could be some differences with they way they get there shots but with a 125 shot with our system you would see around 125 hp and probably a little more than130 tq.
