01 ls1 camaro window switch wiring help
Were do i get the tps wire
And the ighition signal wire
And the shift light aslo
Im wiring up a nos window switch
Fbodyjunkie06 Ignition signal? You mean rpm signal?....
Thats what its say on the paper so im thinking it means rpm signal were do
I get that paper say i can off the coil but people say off the ecu
And yeah i have a shift light
Thanks for the help ..
What is the shift light function for on the window switch?
Just trying to figure out NOS reasoning. I guess it's for once you hook up to your rpm signal you can have it output to a shift light instead of having a separate shift light tapped into the same wire the window switch is tapped into. Guess it makes it cleaner and simpler install. If the shift light is already operational I wouldn't worry about it. I guess it's also for accuracy so if you tach reads slow or fast your not shifting before you need too or after your window switch cuts off. That way your shifting verus the rpm the window switch is seeing.
Word on the street saying u hooked up a kit on it not to long ago that's just what I heard but I got to get my kit hook up just trying to find out there them wiring go for my window switch ..
Yea well the car has never been sprayed.. Idk what or why people would say what u heard.. Good luck with the wiring.. This is not my territory otherwise I would help.. June is right around the corner lol
