NGK BKR6EGP 7092 Spark Plugs??
I've been trying to run down some NGK BR7EF plugs locally. I called around and referenced the NGK part number of 3346, and two of the places said that part number was replaced by #7092, which I looked up and is a BKR6EGP.
Is this plug going to work, or is it a projected tip?
Any guidance would be greatly appreciated!
that plug is totally wrong. The 7092 is a gasket seat, projected plug, with a slightly longer reach.
They should have 3346 at most stores. If not we always have the, if you need them.
