nitrous, pcm tune ?? or 2 pcms?
how many guys run 2 individual pcms for their setups.
Such as 1 pcm for everyday driving on a N/A setup with whatever your setup may be. radical or not
Then get to the track and the 2nd pcm tuned for nitrous with timing already pulled from that pcm. So in turn you just plug it in, start the car up and get to the track and spray the car. The pcm is tuned for the spray and timing is already removed say for a 150 shot. So all thats needed is a full bottle and lead foot.
anyone? ideas? suggestions? comments?
Mostly all that needs to be done on nitrous is to pull timing and the PCM can be tuned on the dyno for naturally aspirated and get a timing box and interface it with your coil packs and pull out the desired amount of timing and it will only be triggered when you hit the spray.
There is another way to do it using HPtuners and a resistor in the IAT but that's complicated and I will let the other guys who do that chime in about that.
Here's how you accomplish what you're looking to do:
https://ls1tech.com/forums/nitrous-o...de-system.html
That requires you to already have hp tuners and then going thru the trouble of making that and wiring it up. Its really not cheaper unless you have hp tuners already then you still need to know what you are doing in there. With the lingenfelter box I can install it in 5 minutes and use a pocket screwdriver to pull the desired amount of timing. Plus I get a launch control out of it too.
My personal opinion would be to go with the LNC-002 due to simplicity and the added launch control, but if you're looking to pinch pennies, what I've already posted is the way to go if and only if you have access to HPTuners.
the easiest way ever is to wire your engine temp sensor on a switch so when flipped it grounds out the sensor causing the engine to pull timing. set in hptuners how much timing you want pulled and thats it. flip and spray away.
I do believe MRK Motorsports sells the dual flash PCM. I bought one, just havent put it in yet because I was waiting on my other block and FI but I think I'm going to throw it in soon as I am thinking about taking the nitrous route for now. All you do is purchase it, solder 1 wire in that goes to your switch where ever you want it for easy switching between tunes. Frost used to offer them, i'm sure theres a thread on here that explains everything in detail.
SPOOLED UP said nothing about cost and/or whether or not he already has HPTuners or if it's available for use. Then again he does say the 2nd PCM would be "tuned" which somewhat implies that he does intend have access to it. This option is cheaper than the LNC-002 if there's someone in the area with HPTuners ($100 for the credits and $30 for the hardware).
If you go that route, have somebody that has HPT do the tune and then decide to up your shot, you're screwed until you can get back with that person.
