Nitrous to a 427R ROUSH Engine... what is possible?
Hey Guys... I know this is for LS1's but...
I have a question about my Mustang which you guys might have the knowledge to answer...
I have a 427R Smallblock Ford in my Mustang, and was wondering how big a Nitrous boost I could throw on it without risking a blowout!
It's a 545HP Engine built on a Dart Block! With a TKO600 Trans (in case some of you also know anything about Fords)
Hope to get a feeling on what is possible!
Thanks
Thanks
everyone one here will need to know more about the motor
Comp?
what internals?
cam?
Heads?
what gas will you run, that question is too broad for an accurate answer, try and give as much info as possible and someone can help out.
Comp?
what internals?
cam?
Heads?
There are quite a few companies who build a 427 SBF with the Dart block. Who built the engine. It is dependent on multiple factors, what pistons, what rings, fuel, EFI or Carb, what rods, what crank.
A little more info would go a long way.
Also isn't the 427R moniker fords attempt at dipping into the ol' nostalgia bag for sales? The 2010 427R is a 4.6 Mod motor with a blower.
This is what I know of it...
Built by ROUSH Performance Engines
427 cu. in. small block ford engine power 545 hp 535 ft lbs tq
Dart 4 bolt main block
Eagle forged crank
Eagle forged H-beam rods
10-1 compression ratio
Wiseco forged pistons
Total seal upgraded rings
Crane Camshaft
double roller timing chain
Melling high output oil pump
Canton front sump oil pan
Hydraulic roller camshaft
Holley mechanical fuel pumps
Air Flow Research (AFR) ALUMINUM CNC PORTED HEADS 205cc
Edelbrock Victor Jr Intake manifold
Holley 870 Street Avenger carb
MSD Distributor
it also has aluminum pulleys, ford racing plug wires
I'm from Denmark (Europe) so it runs on 99 Octane V-Power
Eagle forged crank
Crane Camshaft
MSD Distributor
nice setup. I put a 427 (stroked 351) in my old Mustang. I WOULD NOT hit that motor with a lot of nitrous!!!!!
The crank throw is such that I had to clearance the block and oilpan to allow the crank to swing with no interference. The piston wall side loading had to be high.
I think it could take a 200 shot, maybe a lot more but its not going to tolerate timing and fuel mistakes.
