Figured out how to mount a micro switch to work with a Fast 102 and e/water pump
So I had a TNT kit on a Fast 90/90 set up that I wanted to make work with a Fast 102. I brought a Nitro Daves 102 2 stage plate and thought with some grinding I might be able to make it work. Not a chance, the e/waterpump is in the way. With the plate kit I got from Nito Daves was a small plate with 4 holes and 2 were threaded. I have no clue what this is used for with the kit but I used it for other things. I mounted it on the threaded bolt that holds down the cross over coolant lines.Then I bolted down the micro switch in the treaded hole. This will swivel to give you the right angle you need to mount the switch. I also must have flipped the micro switch around a couple of times so I'm not sure which way it ended up going on so might want to eye things up befroe you put it on. I had it on and off at least 5 times before I had it right . I also only had the top mounting bolt going threw the micro switch so I could move it where I wanted it.I used a nut and washer as a spacer bottom bolt for the micro switch to get the switch were I needed it. I took some pics. Maybe this could help someone down the road cause I couldn't find anything when I searched. Seemed like everyone just used a tps activated switch instead.
