Last Chance To Get Maximizer III!
We have run our final batch of our Maximizer III before we discontinue them since the Max 4 have replaced them.
These are a programmable progressive controller for your nitrous system that will allow you to "Ramp in" your nitrous so that you can run a large single stage without traction issues.
This unit can be setup to progress on a Time, RPM, and Throttle based percentage. This will allow you to bring it with several different variables that a basic window switch wouldn't allow you to do
We have a limited amount of units coming off of the production line so don't wait. Place your order soon.
Here is a link to the unit.
http://nitrousexpress.com/product-details.php?id=1438
Trey
Trey
Kinda off subject but I was reading up on the maximizer 4 and noticed that it has an input for a wideband. Since it is not included what is required to get a wideband hooked up to take advantage of the afr function? Also what particular wideband is the unit designed to use? Thanks in advance!
Trey
