Will I gain hp switching from nozzle to plate setup?
This is a brand x single nozzle kit. I'm thining of buying a plate kit so I can pick up some power while spraying. Right now it is located bewtween the maf and tb with a nozzle and sometimes doesn't stay perfectly straight and gets on my nerves. My main question is should I pick up power go with the plate?
The only way you will pick up power that way is if you are having to soften up the tune-up because of bad distribution or spray more.
How much are you spraying? How are you tuning?
