quick wiring question, zex tc window switch
Old 07-24-2012, 06:54 PM
Go On 3's Avatar
Default quick wiring question, zex tc window switch
i have a nitrous outlet 102 plate kit and i just bought a zex traction control window unit and could use some help on the wiring
basically this is the way i have my nitrous wired up as of now
this is the way zex says to wire it
edit* how would i wire this up using my current wiring setup(the white wires is what im a little confused on)? or should i switch to wiring how the zex diagram is
Old 07-26-2012, 09:29 AM
Go On 3's Avatar
Bump any1?
Old 07-26-2012, 10:30 AM
370cidZ06's Avatar
red- arming switch
Old 07-26-2012, 10:41 AM
370cidZ06's Avatar
try one of these i think the 2 or 3 down is waht you need just eliminate the fps
370cidZ06's Avatar
http://www.nitroustech.com/forums/showthread.php?t=64
Old 07-26-2012, 12:57 PM
Go On 3's Avatar
Thanks, I saw that one but wasn't sure if that would apply to the zex units also, I'll give it a shot and see, thanks
Old 07-26-2012, 01:48 PM
370cidZ06's Avatar
No prob might have different color code on one wire but u should be able to decifer it by where it goes
Quick Reply: quick wiring question, zex tc window switch
