max nitrous size?
Old 07-26-2012, 09:03 AM
hotrodth's Avatar
Default max nitrous size?
Have a stock bottom end 2000 ls1. Stage 2.5 5.3 heads. 233/239 cam. Pacesetter lt. Wondering what would be the most spray I can run. I know 150 is ok but does the shot size change after heads and cam?. Ill be running a dry kit. I have racetronix 42s and walbro 255. Duty cycle is at 55% now at wot.
Old 07-26-2012, 09:15 AM
Neal@NitrousOutlet's Avatar
What are you making NA power??
Old 07-26-2012, 09:27 PM
hotrodth's Avatar
Guessing 420-445at the wheels.
Old 07-27-2012, 08:53 AM
I would start out with a 100 and see how the car reacts. The 150 might be putting your pump on the edge if not over on what it can support. Injector wise you should be fine.
Old 07-27-2012, 10:58 AM
ShiznityZ28's Avatar
We had a car with 250 on a walbro this was a wet kit mild h/c street car. it was out of fuel but went 9.8 in a 3700lb car
Quick Reply: max nitrous size?
