Bottle Heater Thermostat Question
I have 2 NOS bottle heaters P#14164 that I'm running on 10lb bottles. I want to replace the Thermostats with Pressure Switches so I can actually bring the PSI of the bottle up in the heat of the day. Wanted to know if anyone knew the correct P# for the switches or complete kit.
or
How can I heat the bottles in 90 degree weather the correct way?
or
Guest
Posts: n/a
You will comepletely remove the thermostats and sub in the transducer then will have to rework the wiring a little.
Here is a link to our heater transducer
http://www.nitrousoutlet.com/catalog...84&product=992
Also check this link out and look at the heater instructions as it will have a diagram you can look at. http://www.nitrousoutlet.com/manuals.asp
