How big of a dry shot and still be safe w/my setup?
Old 04-05-2004, 04:11 PM
horist's Avatar
Default How big of a dry shot and still be safe w/my setup?
11.3:1 compression
Walbro 255 in tank fuel pump
FMS 42lb injectors
Stock MAF w/screen
382 rotating assembly in LS6 block
232/240 593/603 112 camshaft
Shifting at 6400RPM or so (so I'll shutoff the nitrous at 6300)
... is 100 about as high as I should think of going or think it'd be ok w/a 125 shot? Timing is 25-26 degrees at WOT ... should I pull a few degrees of timing as well? (I have ls1 edit)
TR6 plugs are going in this weekend along w/the nitrous kit...
thanks!
Old 04-05-2004, 08:10 PM
383LQ4SS's Avatar
Well..your setup is similiar to mine. I have a hotwire kit for the pump and just added the volt blaster. I have sprayed up to a 300 shot dry. in two stages of 150 each. First stage at 3000 rpm and the second dtage coming on at 4600. If your tuning for your injectors is correct...you should be safe to 650+ rwhp or more. Just take it slow...use 100 octane and pull 2 degrees for every 50 hp of juice.
Remember...timing retard is your friend.
