Plug Reading Thread
Old 08-19-2012, 04:26 PM
10secZ28's Avatar
Default Plug Reading Thread
I wanted to share a nitrous plug for anyone interested in learning to read plugs, this is a plug out of my buddy's car that i tuned yesterday, it is a full bolt on camaro with a vic jr and 4150 tb with a Nitrous outlet spray bar setup, this was done on 93 octane pump gas pulling from the rail with and ngk 7 plug. His base timing was roughly 28 degrees so i pulled him down to 19 to start the first pull and make sure his fueling was close i believe he has a 70n 34f in it and after the first pull the fuel looked very close, so we loaded up some more plugs and made another hit and i started sneaking a degree of timing in until 3 pulls later we were at 21 degrees total with a little heat starting to show on the plug. All pulls were done in viva la mehico
I personally think its a touch on the lean side, but given the conditions to tune in i think we did a pretty good job On a side note i wanted to get one cut open for everyone to see bit we havnt got that far yet.
Old 08-19-2012, 05:33 PM
Sales@Tick's Avatar
As I told you yesterday Brandon that plug looks very good for the short amount of time you had to get it there.
I'd like to see the honey color a little further towards the tip, but other than that I think it looks great! Maybe a 35f jet and see what it looks like then!
For those looking for a good plug to reference this is it!
Old 08-19-2012, 05:36 PM
Sales@Tick's Avatar
Oh yea......VIVA LA MEHICO!!!
Old 08-19-2012, 07:13 PM
10secZ28's Avatar
Thanks Martin, I actually pulled him down about a half a degree and called it a day after this, i feel this tuneup should be very safe for him
Old 08-20-2012, 07:46 AM
Sales@Tick's Avatar
Looks real good.
Brandon, sorry I didn't call you back, I will try to get in touch with you this evening.
Old 08-20-2012, 09:16 AM
ATVracr's Avatar
If it only has a short run on it then I would say it has to much timing.
Probably little lean also for a short run plug.
If it was a full 1/4 mile plug I would still say pull a couple * out and see if it likes it.
1/8th mile or shorter run it looks to hot.
JMO.
Old 08-20-2012, 09:18 AM
10secZ28's Avatar
it is a 2nd through 4th gear pull just shy of a full 1/4, it definitely responded well each degree i added to it, also wayne this plug has 2 full pulls on it, heat was not showing after the first pull so i added 1 more degree to it and it clearly showed heat on this one.
Old 08-20-2012, 10:01 AM
Burrhos's Avatar
I know this car. . .
I should really do some plug pulls for my baby .052 jet to get ready for the big boy pills in the future.
Great thread, thanks for sharing
Old 08-20-2012, 10:24 AM
ATVracr's Avatar
After hearing that I'd say its real close, keep and eye on it when the air changes. Good luck with it.
Old 08-20-2012, 10:36 AM
10secZ28's Avatar
I appreciate your input as always man! And yes we had micro switch problems later that night so i will be monitoring his tuneup after he gets it squared away again. he freight trained that 2011 5.0 mustang though lol
Quick Reply: Plug Reading Thread
