View Poll Results: Best nitrous filter location
two filters, each installed immediately after the bottle nipple, but before the Y-fitting?
1
33.33%
one filter, installed immediately after the Y-fitting?
1
33.33%
one filter, installed immediately before the solenoid?
1
33.33%
Voters: 3. You may not vote on this poll
Best nitrous filter location?
Old 08-23-2012, 09:07 AM
Somebody09's Avatar
Default Best nitrous filter location?
I'm have the NX Shark nozzle with the 62 jet (150 HP I think), the really old NX Iceman solenoid, and a -4AN feed line. I'm also using two 10 lb bottles Y-ed together. I bought two filters from NX (#15607) because I thought it'd help flow, but if one is enough, then I'll use just one. Where's the best place for the filter(s)?
I guess all these threads mentioning phase change and whatnot have me questioning what could go wrong with my setup ... currently un-filtered.
Old 08-23-2012, 10:17 AM
Chris@NitroDaves
Guest
Posts: n/a
The filter needs to be as close to the bottles as possible.
There is no need for two filters as it has the potential to cause a restrction in the system.
Old 08-23-2012, 05:44 PM
Somebody09's Avatar
Well I don't understand the restriction part, seeing they'll be run in parallel and not inline.
Old 08-24-2012, 10:35 AM
Chris@NitroDaves
Guest
Posts: n/a
I guess i overlooked the fact that you were going to put them before the Y so each bottle has a filter. There will be no restriction in doing this. I guess i pictured you running them inline together.
My bad...Your good to go.
Quick Reply: Best nitrous filter location?
