Whiteltone stock cube beater V2.0
Old 09-18-2012, 08:59 PM
StrokerTA's Avatar
Default Whiteltone stock cube beater V2.0
Well it's been over a month since we went out last, I think we ended with a 6.09@116?? We have since made a few revisions.
Nicks original motor was built 5 years ago as part of his swap from his 396lt1 to the LS world. It was going to be a street/strip car.. Well after I got it apart I realized just how "street" it was.. The old engine was just at 10:1 compression, so I suppose our 6.09@116 with 200 jets in the plate wasn't all bad..
I just got the cam degreed and got the rest of the short block together. It's now 12:1, sporting some new Compstar rods, polished factory crank with a few little tricks just to make it spin a little easier. And the top half of the engine remains the same, except we did send the plate system to Steve @ Induction Solutions so he could tell us just how out of whack it was.... and it was....
So Nick should be picking the engine up tomorrow, and get it stuffed back in the car, I'm taking Friday off to help him finish it and then to the track we go Friday to see what the new bullet has got!
Old 09-18-2012, 10:18 PM
Boosted Firehawk's Avatar
Should run well I can imagine.
Seems kind of sluggish running low 6s in a 396 on the ****.
Is it a heavy car?
Old 09-18-2012, 10:25 PM
StrokerTA's Avatar
Is it a heavy car?
Sorry, that was kind of confusing the way I typed that up.. The 396 lt1 was replaced about 5 years ago, thats when we built the first stock cube ls1 which was 10:1.. With work, buying a house, etc.. It just took Nick awhile to get the car out..
6.06@116 is what we went with a stock cube ls1, 10:1 compression, custom ground cam, Dart 230's and a Vic Jr with a NX plate kit(200 jets) and a Quick Fuel 850 carb. Car is about 3,000lbs..
Old 09-18-2012, 11:06 PM
WhiteLTone's Avatar
Hopefully still under 3000lbs. Car has been 118 in 1/8th on old shortblock. Good news is we put a little more thought into this setup and with it being a true nitrous motor and the fact i finally took my dress off, im looking forward to good results!
Old 09-20-2012, 10:44 AM
StrokerTA's Avatar
After a slight hang up last night into this morning, and a few minor adjustments. Nick just left the shop with the new bullet and is heading home, to sleep... Then get the engine stuffed in the car and ready for tomorrows track rental.. Tomorrows weather is forecasted @ about 60* with relative humidity under 40%, I hope the track is on kill because this bitch is gunna rock!
Old 09-28-2012, 07:55 PM
StrokerTA's Avatar
The weather is finally going to let us out tomorrow, air should be good, track should be on kill because we are testing a few pro mods also. Hopefully she does what we think it will!
Old 10-01-2012, 01:08 PM
StrokerTA's Avatar
Got 2 spray hits on the car Saturday.. First hit went 9.58@130 with a 1.40 60', Nick got caught off guard when it started going OTB for the first time in it's life..
2nd hit it went 9.53@143 with a 1.48 60' track started going away.
Should be going back out tomorrow or Wednesday. She makes plenty of HP on the 200 jets! Just gotta fine tune the first 330' of the track.
Quick Reply: Whiteltone stock cube beater V2.0
