Why is an F1 kit limited to a 150 shot.........
Old 04-16-2004, 04:11 PM
Quickin's Avatar
Default Why is an F1 kit limited to a 150 shot.........
What is actually limiting it from taking a larger jet?
How much does it cost to be able to use a larger jet?
Old 04-16-2004, 04:22 PM
Turo's Avatar
i know the F2 uses bigger solenoids, not sure of the F1's are maxed out with the 150 though
Old 04-16-2004, 05:10 PM
SSU Moderator
RyanJ's Avatar
thats just the largest jet pack they send with it. it should use the same sol. as the F2. has for a while I believe.
Old 04-16-2004, 05:39 PM
Quickin's Avatar
Well, if I buy an F1 kit from a guy, what do I need to do if I want more than a 150 shot?
Also, if you go from a 150 shot to a 200 shot, does the engine need to be re-dyno tuned?
Old 04-16-2004, 07:53 PM
Ben R's Avatar
If you're going to spray a 200 shot, you probably won't want to do that on straight 93 Octane. You won't NEED a re-tune, but it would be ideal. You might also want to upgrade fuel pumps and think about putting a slightly larger jet in the fuel side of the kit just to keep things on the safe side. You'd hate to blow up that expensive 436 Super-Stroker.
EDIT: Also, you might want to think about ordering bigger solenoids for the 200 shot. Even though I'm sure TNT will tell you that you'll be okay, I would option for the larger solenoid, just to be on the safe side.
Old 04-16-2004, 08:38 PM
Quickin's Avatar
I'm already planning on using a fuel cell with 100 octane in it to feed the wet shot.
So, all Im have to do is change the jets on an F1 TNT kit to be able to spray a larger shot? Also, change the noids and fuel jets.
So, will that basically make it an F2 system?
Old 04-16-2004, 08:57 PM
Ben R's Avatar
You'll be fine to add the larger pills for the bigger shot on your F1 Kit.
Check out Derty's article on www.derty.org about his standalone fuel system. It's a GREAT place to start.
Old 04-16-2004, 11:04 PM
Quickin's Avatar
Thats a nice set up he's got. I want to put the fuel cell my the fuse boxes. I don't want to move my battery.
Old 04-17-2004, 01:04 AM
Chris99WS6PWTMET's Avatar
I'm pretty sure all the F1's now come with the big noids. Mine did, and I bought it about 6 months ago. After talking to TNT about jetting up I was told that the F1 kit's -4 feed line becomes the limiting factor above 150. Swapping in a -6 feed line and bigger jets should most likely do the trick.
Old 04-17-2004, 12:29 PM
SStroked 410's Avatar
I would just try larger jets, they sell them
thats what I am doing with my NX wet kit.
Old 04-17-2004, 09:55 PM
SSU Moderator
RyanJ's Avatar
-4 line limiting at 150hp? thats news to me. -3 maybe.
Old 04-17-2004, 11:22 PM
C4VetteLS1's Avatar
Actually the F2 kit used to the same as the F1 kit, other than jets. But the F2 kit was recently revised (they should call it a F3 kit now).
the standard F1 kit will work up to about 250 rwhp.
The new revised F2 kit, comes with 6an feed line, moves the 6an n20 filter up to the engine bay and uses larger solenoids, it also replaces the 3an lines that ran to each fogger with 4an lines now. It is now adjustable to 350 rwhp.
Old 04-17-2004, 11:37 PM
Ben R's Avatar
Are you sure about the F2 Kit having the nitrous filter in the engine bay? I recently installed an F2 kit on a 99 C5 Vette and the nitrous filter was designed to be located about 6 inches after the bottle.
Old 04-17-2004, 11:43 PM
Quickin's Avatar
So, BOTTOM LINE
If I buy this F1 kit from this guy I can spray MORE than a 150 shot without having to spend allot of money, right?
Old 04-17-2004, 11:47 PM
Ben R's Avatar
Yes.
You'll need to buy the larger jets for the bigger shot (About 10 bucks for a pair of jets), and perhaps a bigger fuel solenoid, which runs about $120 bucks. If you're not going to spray anything over 200 you will be fine with the solenoid that you'll be getting with the kit.
Old 04-18-2004, 04:41 PM
C4VetteLS1's Avatar
Correction to kingcrapbox's post: You will not have to purchase anything larger on a F1 kit to spray a 250. Only the jets. The larger solenoids are only in the newly revised f2 kit that sprays upto 350 rwhp.
Old 04-18-2004, 07:57 PM
Ben R's Avatar
You confused me.
I suggested he buy the bigger solenoid to make sure that all of his fuel is there when he needs it, it's not a necessity, but a wise purchase if he wants to minimize the risks.
Old 04-18-2004, 11:03 PM
02NBMZ's Avatar
I heard this straight from TNT. " A 4-AN line will not support more than 150 shot" If you want to get more than 150hp from a nitrous kit I would invest in a 6-AN line.
Old 04-18-2004, 11:32 PM
C4VetteLS1's Avatar
You couldnt have heard that from TNT. I deal with them all the time. I spent hours on the phone with them just this last week going over several kits i was doing for customers.
A 6an line is a good idea, but not at all nessesary. Ive had tons of cars put down 200-225 rwhp on a 4an line.
