N20 kit on a Edelbrock pro flo xt
Old 03-19-2013, 12:57 AM
1MeanGreenZ28's Avatar
Default N20 kit on a Edelbrock pro flo xt
Im in the process of building a lq4 motor for my 99 z28
I have a Nitrous Outlet kit with hard lines and 78 mm plate
I know a lot of ppl run the pro flo xt with boosted applications but I wanted to see if anybody is running this intake with n20
I know my plate and hard lines wont work but what could I do to run spray on this intake?
I would like to see some pics if all possible
any help would be awesome!
Thanks!
Old 03-19-2013, 12:30 PM
Anybody?
Old 03-19-2013, 01:08 PM
Justins00ss's Avatar
If your looking for a simple way to run spray, just plumb in a single or dual fogger before the TB using your exsisting noids and call it a day. It might not have the same distribution properties as a plate but it will get the job done for sure.
Old 03-19-2013, 02:14 PM
oh ok thanks!
Old 03-20-2013, 10:30 AM
5.0 LsX's Avatar
i wouldnt throw a 78mm plate on that either, unless you have a 78mm t/b that will bolt up to it...it is a good intake, if you have the room for it
Old 03-20-2013, 06:54 PM
yea I would need a 90 or 92mm plate and tb
Old 03-20-2013, 07:01 PM
Tweek's Avatar
Im running the pro flo intake and edelbrock TB with a nozzle kit right now. Ordered a 90mm plate just to make it look alittle cleaner. Future plans are direct port with nozzles in the runners, so easy to drill and tap this manifold.
Quick Reply: N20 kit on a Edelbrock pro flo xt
