about to spray
Old 05-12-2013, 07:03 AM
JDEP162's Avatar
Default about to spray
Soon i will be spraying for the first time, before id do, can anyone tell me what to watch for before/during/after. As far as afger the run look under the hood for? Or check valve x, etc. I plan to check all the connections, but what are the things to expect either good or bad.
Old 05-12-2013, 07:23 AM
HCI2000SS's Avatar
Well running the correct plugs and checking them would be a good start. Have the proper amount of fuel is imperative as well
Old 05-12-2013, 11:27 AM
2birdJosh's Avatar
If you do it do it right. you need window switch timing to be retarded fuel pump injectors purge valve bottle heater if run in cold weather.Nitrous is cool but can come with lots of problems if not set up right!
Old 05-12-2013, 08:37 PM
totalchaos's Avatar
bottle presure and weight.
Old 05-12-2013, 08:42 PM
FoHawk's Avatar
cops?
Old 05-12-2013, 10:28 PM
JDEP162's Avatar
good advice, got the bases covered, timing pulling, bottle heater, purge, fpss, not worried about cops, just wanna know what to check here and there. pulling plugs to check them doesnt sound fun, but thats the breaks.
Old 05-12-2013, 10:41 PM
Blackpanther99's Avatar
Yeah running bad spark plugs isnt good in the first place soo with nitrous even worst. Taking it to the track? Or will this be on the streets of Mexico?
Old 05-13-2013, 01:36 AM
JDEP162's Avatar
plan to take to the track on the 24th, other than that will be on the streets, of mexico of course. got the new plugs (ngkbr7ef), and msd wires.
Old 05-13-2013, 07:44 AM
Hope it goes good for you bud. What are your mods?
Old 05-13-2013, 09:50 PM
JDEP162's Avatar
So far, lid , lm2 exhaust, nothing major yet. Want to try some small shots of spray, see how it goes. Did all the supporting stuff for spray.
Old 05-14-2013, 09:49 AM
FoHawk's Avatar
go 125pills all day
Old 05-14-2013, 10:09 AM
2birdJosh's Avatar
Talking
agree with 125 shot! You want to be able to feel it!
Old 05-14-2013, 12:19 PM
35th SS's Avatar
stock fuel pmp. or aftermarket?fuel press. gauge to get a glimpse when you hit the nitrous.
Old 05-14-2013, 03:39 PM
JDEP162's Avatar
Yep planning on the fp gauge, also plan to do wideband and n20 pressure gauge soon too.
Old 05-14-2013, 04:47 PM
35th SS's Avatar
also might want to install a blowdown tube just in case too much press. on the bottle.bottom line think safety.
Old 05-14-2013, 04:55 PM
brandon@nitrousoutlet's Avatar
Have you made a pull yet? Be sure to shoot me an update!
Old 05-15-2013, 02:39 AM
JDEP162's Avatar
Yep got blow down tube, wanna be safe for sure. Will do brandon, gotta get bottle filled this week, then were gona hit it, thanks.
Old 05-15-2013, 11:31 AM
35th SS's Avatar
submerged bottle in full of ice in a cooler before you get it filled.just a plus youll get a little more and fills faster.Happy spraying and post up.
Quick Reply: about to spray
