solonoid leak help
Old 06-05-2013, 09:06 PM
JDEP162's Avatar
Default solonoid leak help
No matter how much or little teflon paste, i keep getting leaks around the lines at the solonoid. Do i need a higher grade teflon paste or what?
Old 06-05-2013, 09:28 PM
boostit5.3's Avatar
i always use the tefflon tape.... i know they say not to but i only use a little bit and take extra caution to not get any inside the solenoid, and i never have any leaks (knocks on wood).
Old 06-06-2013, 04:33 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
You can also try using a blue or red lock-tite to seal up the threads. I highly recommend not using tape because it doesn't take much to clog the tiny hole in the jets.
Trey
Old 06-07-2013, 05:51 PM
JDEP162's Avatar
Thanks thats good advice, ima try the blue thread locker.
Quick Reply: solonoid leak help
