C5 dies on nitrous
C5 dies on nitrous
I'm spraying 150 shot on my C5. Only mods are Vararam, Ported LS6 intake and corsa mufflers. I'm running the dynotune kit controlled by a NOS window switch. When running the car on nitrous it will pull fine, but then die after the run. After cranking for a bit it will start up and run just fine, no issues what so ever. ECU isn't saying that it has ever had a lean condition. I have my WOT switch set to open at 4.2v on the TPS and between 3100 to open and 5800 to close.
There are my plugs.
Any ideas? I have found a few things that say you need to slow down with the car in gear otherwise it floods out. Which would make sense because the car will restart and run fine...
There are my plugs.
just re-read your post. I see you car is mostly stock. Yeah, I would not really expect it to flood out and not want to restart right away.
Are you spraying before the MAF?
That first plugs seems to have a little more spark/heat than the second which is not unusual for a plate, but overall the AFR looks rich to me. I think this is contributing to your situation.
I would like to see a little more heat in the cylinder by leaning it a little.
Based on the first plug, may wanna take 1 or 2 deg spark out before doing it.
Stock timing, stock tune. Made one pass on 150...car died and then started right up and ran fine, but didn't wanna spray again. Jets are as recommended .64 nitrous .38 fuel.
I ran it once on 150, beat a bolt on new 5.0 mustang by walmart lengths, and never did it again! I have it on 75 now, and runs well. Putting a racetronix in it, finishing up the exhaust and getting it tuned.
stop beating up on the tards. you got to beat an lsx to be legit.
