9s stock bottom end 6.0
Old 07-06-2013, 12:04 PM
Ls_Notch's Avatar
Default 9s stock bottom end 6.0
Finally got to the 9s. Went 9.82, 9.70 and finally a 9.59@139 on the limiter with a 150 shot. Now it's time for the big jets!
Old 07-06-2013, 12:08 PM
Blackpanther99's Avatar
Wow very nice! Mind sharing the specs on the block? What was your 60'?
Old 07-06-2013, 12:44 PM
Ls_Notch's Avatar
It's a stock 02 lq9, prc stage 3 243s, flow tech custom grind, Vic jr, Holley ultra hp 850 carb, kooks long tubes, glide with a ptc stall. It went a 1.37 on the 9.59 pass
Old 07-06-2013, 01:30 PM
dmracing's Avatar
Have under under hood shots.
Old 07-06-2013, 04:24 PM
Ls_Notch's Avatar
here is the slip from the 9.59 pass
Old 07-06-2013, 04:42 PM
Bobatsuperior's Avatar
Nice, if you don't mind if I ask what kind of money do you have invested in it?
Old 07-06-2013, 04:49 PM
Ls_Notch's Avatar
I kinda lost count ha if I had to guess I'd say right around 10k, I don't think that's bad for a easy mid 9 second car that should go quite a bit faster, it also drives nice down the road too and never gets hot, I'd like to run drag week with it someday but we will see
Old 07-06-2013, 05:46 PM
Charles Cyrus's Avatar
Congrats!
Old 07-06-2013, 05:52 PM
dennis50nj's Avatar
Nice great times, I want to spray mine at the track someday
Old 07-07-2013, 06:30 PM
Ls_Notch's Avatar
Thanks guys, this was still with a pretty fat tune and 8 deg out, I think it will go 40s on a 150. The da was 2800+ too
Quick Reply: 9s stock bottom end 6.0
