Cutting plugs at track....
Old 07-12-2013, 12:30 PM
streetknight2's Avatar
Default Cutting plugs at track....
Thought I'd share how I do it and maybe someone has a better way, but this works great for me.
I started with a piece of box tubing and drilled and tapped it 14mm x 1.25 for the plugs. Make the piece of tubing long enough so you can stand on it.
Screw the plugs in the holes, then use a 5/8" hole saw with no pilot in a cordless drill and drill until the ceramic part pulls out. quick and easy.
Hope this helps someone, thanks to Mr. Jackson for telling me.
Old 07-12-2013, 03:46 PM
KTK Z28's Avatar
Very cool. Thank you for sharing. That is a very convenient way to cut plugs.
Old 07-12-2013, 03:56 PM
87silverbullet's Avatar
That sure is neat. I use a cutoff wheel at the track. We have electric plug ups at one of our tracks.
I have also heard of putting the plug in a drill and running it up and down on a hacksaw blade.
Old 07-12-2013, 04:36 PM
brandoz28's Avatar
This is how I've always done it
Old 07-12-2013, 05:13 PM
James@ShorTuning's Avatar
Drill against a blade is how I've always done it. On the dyno I have a porta-band so I can really get them cut off quick.
Old 07-12-2013, 05:19 PM
EdgarB's Avatar
So I guess I will take a hit here and ask otherwise I won't learn.. Why do you cut them?
Old 07-12-2013, 08:08 PM
Killer5.3's Avatar
To make it much easier to see the fuel ring on the bottom of the tapered part of the porcelain. That tells you if the engine is rich, lean , or just right and people that mainly use nitrous do this. In this case the fuel ring is really dark so it needs fuel pulled from the nitrous tuneup.
Old 07-12-2013, 08:30 PM
Carter01's Avatar
Chuck the plug in a drill, use a 32 tooth hacksaw blade and let her eat. Very cheap and effective!
Old 07-17-2013, 10:28 AM
nicentech's Avatar
You can buy a electric cut off wheel at harbor freight for like 20 dollars that works wonders... sllices right thru the metal like butter and the cutting disc will not cut the porcelain
Old 07-17-2013, 02:00 PM
That's if you have electric at the track.......
Old 07-17-2013, 04:50 PM
Roger Blackmore's Avatar
Op. how long would you say it takes to cut 1 plug with the hole saw?
Old 08-14-2013, 07:05 PM
Old School Heavy
speedtigger's Avatar
That is a slick idea.
Old 08-17-2013, 08:55 AM
Op. I'm asking again, how long would you say it takes to cut one using your method. Ive had to start using a gasket seat plug, and it takes a lot longer to cut with a drill and hack saw. So I'm thinking about trying your method.
Thanks
Roger.
Old 08-17-2013, 09:01 AM
30 seconds after everything is setup
Old 08-17-2013, 09:02 AM
Ok. Thanks. I'll give it a try.
Quick Reply: Cutting plugs at track....
