Surging
Old 04-29-2004, 07:53 PM
Sigma's Avatar
Default Surging
Ok guys, got a question for you nitrous guru's. I have a 99 a4 ls1 NX wet kit. I currently have a 100 shot and it seems to make the car surge after 100mph. My pressure was about 950. The only thing I can think of is that I'm using a 52 jet for the nitrous and a 31 jet for the fuel instead of the 28 jet like it says on the NX chart. I did call NX and they said that using the 31 jet was acceptable. Hope I make sense. Any input?
Mods are LT'S, oryp, lid, NX 100 Shot.
Old 04-29-2004, 11:48 PM
Slow TA's Avatar
I think I might be having the same problem. When the spray kicks on at 3000 it will be normal then it seems like when it hits about 4500rpm it surges. Is this bad on the motor at all or is it normal with NX kits. BTW my bottle pressure was about 900ish also
Old 04-30-2004, 10:21 AM
Chicago Z06's Avatar
if your using the fuel pressure sensor take it out of the loop and see if it clears up... the hobbs switch has been the culprit in most cases... if your not using this switch and your still seeing pulsing have a FP gauge connected when you run the car to see if the FP is fluctuating.... if this is not it then the bottle can be getting empty even with the pressure if the liquid is not there you will see a surge as well... hope this helps.. keep us updated on the fix...
Old 04-30-2004, 08:31 PM
Sigma's Avatar
The bottle is full so that can't be it. And by fuel pressure sensor do you mean fuel pressure safety switch? I'm going to have my car tuned for nitrous in 2 weeks so hopefully that will fix the problem. But the bigger problem is that I can't stop using this stuff.
Old 05-01-2004, 08:59 AM
5 Liter Eater's Avatar
Mine does this as well. Pulls hard from 3k-4kish, then looses momentum until ~5k, then picks up steam again until the window switch @ 5800. Did this last night with a totally full bottle and I know my siphon tube orientation is correct.
Old 05-01-2004, 10:57 AM
Sigma's Avatar
has anybody solved their problem?
Old 05-01-2004, 12:58 PM
C4VetteLS1's Avatar
3 jet sizes on the fuel size is very rich. Especially when your not running the bottle pressure up to 1050-1100 like it should be. Factory NX jetting is already a little rich (and is fairly rich @ 950 psi bottle pres). Take that 31 jet out and put the correct jet in (28). Theres no safety reason to run it overly rich.
Old 05-04-2004, 07:26 PM
Sigma's Avatar
Ok guys, had my car dyno'd today.
NA it made 323.13 hp and 335.08 torque.
On the spray it made 378.54 hp and 453.86 torque.
So yeah, something was wrong.
The guys said it might be the spark plugs. They told me to gap the plugs at 35 because from the looks of the graph they think the nitrous might be blowing out the spark. From what i've read most of the people on here have gapped theirs at at least 40 to 42. I'm changing the fuel filter tomorrow because it's been awhile since i've done it.
I'm hoping that it's either one of those things because if not then i'm stumped.
I don't have a scanner but i'm going to try to take a pic so i can post the graph up later tonight.
Any idea guys?
Old 05-04-2004, 09:06 PM
383LQ4SS's Avatar
I have seen several reasons for surge.
As said above...the #1 problem is usually the fuel pressure safety switch set on the edge. But it sounds like you dont have that.
Other items ive seen:
plugs gapped too loose
pulley tensioner allowing belt slippage under hard acceleration (seen that on two cars)
too rich or lean...check Af on the dyno with wideband
Blocked or collapsed lines
freezing maf on dry shot
Old 05-04-2004, 09:30 PM
1QWIKZ's Avatar
also make sure the bottle is fully open. you have no idea how many dumbasses leave it half closed and wonder why it surges.
Old 05-04-2004, 10:33 PM
Sigma's Avatar
There is my dyno graph(blurred out my name for personal reasons).
Erratic if I do say so. Anyways, you can see my air/fuel ratio on there as well.
Old 05-04-2004, 11:19 PM
Robert56's Avatar
auto bottle opener? certain brands have been known to cause surging.
Old 05-04-2004, 11:23 PM
taqwache's Avatar
Old 05-04-2004, 11:30 PM
Sigma's Avatar
no, no remote bottle opener for me.
Old 05-05-2004, 03:28 PM
sounds stupid i know... BUT are you 100% positive there is no kinks in the main feed line anywhere?
Old 05-05-2004, 04:56 PM
1QWIKZ's Avatar
Originally Posted by taqwache
hehe!!
Old 05-05-2004, 06:46 PM
Sigma's Avatar
Yeah no kinks in the line. The last thing I need to do is to check the gaps on the plugs again. Where do you guys have your spark plugs gapped at? Oh, and thanks for all the responses.
Old 05-05-2004, 10:14 PM
Draco's Avatar
Your bottle isn't upside down is it? The siphon tube could be having trouble picking up the nitrous under WOT if it's oriented at the top instead of the bottom of the bottle.
Old 05-06-2004, 12:35 AM
70Stang's Avatar
NGK TR6s at 35.
Old 05-06-2004, 01:25 PM
verbs's Avatar
What kind of window switch do you have? My buddy had a Harlan window switch that made his car surge badly, then he took it off and no more probs.
Quick Reply: Surging
