plug reading with pic, how lean it is? bad n/a tune?
Old 07-26-2013, 02:31 PM
Johnnystock's Avatar
Default plug reading with pic, how lean it is? bad n/a tune?
Plugs 7 and 8 looks bad(car was bucking);
[IMG][/IMG]
others;
[IMG][/IMG]
What do you think? Is is bad or ok?Car was street tuned for nitrous...non even a full bottle on those plugs(less than 4000miles)
I know this wasnt done with brand new plug after one pass, but it definitly seems lean.
Old 07-26-2013, 02:39 PM
brandon@nitrousoutlet's Avatar
Can you cut the threads off a couple of those for me?
Never mind just saw where you've been driving on these plugs. I wont be able to get a good reading on them like that.
Old 07-26-2013, 02:40 PM
I'll do it! ..if you can check this out tomorrow!
Old 07-26-2013, 02:41 PM
I edited my post. What you CAN do is throw a new plug in there and do a short blast on it and I can read that one!
Old 07-26-2013, 02:49 PM
good, I'll do that!!
Old 07-26-2013, 03:40 PM
Doug G's Avatar
Projected tip plug on the juice ?
Old 07-26-2013, 03:59 PM
87silverbullet's Avatar
^^^^What he said. Put a br7ef in there THEN make a blast.
Old 07-26-2013, 04:04 PM
StrokerTA's Avatar
Projected tip and nitrous is a big no-no.. And as everyone else said, you need a clean shut off to get an accurate plug reading..
If at the track change plugs on the top end and drive back, or get towed back.. Only real way to get a good reading..
Old 07-26-2013, 04:21 PM
This. TR6's are no bueno.
Old 07-26-2013, 06:37 PM
Yeah tr6 were fine in 2006-2010 then everyone is saying its crap. My spare plugs are br7ef anyway as Im still reading this forum a bit :-)
Old 07-27-2013, 08:09 PM
lsx2000z28's Avatar
Are br7ef ok off the juice I'm runnin into this problem too. I run na and on the bottle
Old 07-28-2013, 09:57 AM
Yes, they will be ok. You might find it will run a little rougher but it will be ok.
Old 07-29-2013, 07:55 PM
unioncarpenter84's Avatar
heres the plugs I pulled with no nitrous
Quick Reply: plug reading with pic, how lean it is? bad n/a tune?
