Newb lookin to spray my m6...best 2 step & window switch ?
OK I have been thinkin of sprayin my '72 SS ....LS1 H&C FAST 92/92, all boltons . I have a Nitrous Outlet 92 dual Stg Plate kit & will be Starting out with 100 shot for now & Completing the Dual 2nd stg Later.
I did a Search on 2Steps & window Switches with lil Results so I am Lookin to those who are a Veteran with this Setup please. What is your Favorite 2 Step & Window Switch & is this all I will need ,besides a bottle warmer.
Also is there a Sweet Spot RPM wise for Leavin on the Spray ? I have been NA for 7 yrs Leavin on the LMTR @ & 7000 rpm .
Car is 460RWH/425rwtq now ,Built T56,Denny's Nitrous Shaft,Monster Stg 3Clutch Setup,4:11's out back. Thanks for the Input !
lnc2000 , love mine. its a 2 step and timing controller for ls engines. very easy to use.
i like the msd digital window switch if ur lookin for something on the less expensive side. but i got a nos launcher , its a wot switch , a progressive controller, window switch and much more.
LNC-2000 and either the NOS Mini or Launcher would be your best bet. You certainly wont be leaving off the limiter anymore. Every combination is different as far as launch RPM. There are a lot of variables so your best bet is tojust try different RPM's to launch at. A window switch is very important especially for 6 speed guys in case you bog off the start or lose traction and nail the rev limiter.
