Flaws of the NX NXL kit. Can the be overcome?
Got to ask why?
Does it change the spray pattern?
Does the spray pattern hit the NXL nozzle causing a stream of fuel vs a good atomization?
Does it require a different injector timing?
When you say keep it from pulling more fuel through the injector, can you explain more?
Even with a single shark nozzle or plate system, I have seen MAP increase causing the injector duty cycle to rise. Is that what you are talking about?
