HSW microedge/interface HELP tuning
So i bought a microedge controller and the interface and i need help setting it up, at least a basic setup. i tried setting it up the way the instructions said with no luck, so any help would be much appreciated. Running a h/c/i camaro 150 shot through a nozzle. I have the wot set through the tps. When i set it up the way it told me my car ran rich and would die and for some reason it was clicking the solenoids when i first turned the key. All the wires are correct i triple checked the routing once again any help would be appreciated
Do you have instructions for both? Also, remember, you can use + or - to activate. Make sure you are giving the right signal. When I get off work I will check my manuals.
