Need NXL jetting sizes ASAP - please!!!
Old 05-02-2004, 06:06 PM
MeanWS6's Avatar
Default Need NXL jetting sizes ASAP - please!!!
I have 26/14 (180 shot) in their now, What are the other jet sizes and HP the rating that come with this kit
I have 9/18, 10/20, and 26/14
thanks guys
Old 05-03-2004, 06:35 AM
93LS1RX7's Avatar
Those are the correct Jet sizes:
9/18 is 80hp
10/20 is 120hp
26/14 is 180hp
You have something wrong if you didnt feel it. Is your bottle full? What is the bottle pressure? Are you sure your solenoids and safety wiring are wired correctly? 180 shot you should feel for sure no ifs ands or butts about it.
Need some more information on how you have it set up and some more info on what happens to help diagnose it.
If you have a MSD window switch make sure it is set up for 4 cyl mode not the 8 cylinder.
Old 05-03-2004, 09:19 AM
MeanWS6's Avatar
thanks for the info - so I had the right jets
yes, 15lb bottle was completly full - I filled it myself with my refill station
Pressure was at 1000-1050.
MSD window switch is for the 8cyl (same one I used with my old NOS kit)
I have to wonder if its my mounting positon, I am using NX quick release bottle brackets in the trunk of my vert so it lays completly flat. Maybe the siphon tube is not getting all the juice or something
Old 05-03-2004, 07:54 PM
H82BBad's Avatar
maybe you backed around the fuel and nitrous jets and are running very fat ?
Old 05-03-2004, 11:41 PM
C5 YA's Avatar
Your MSD window switch should be set for 4 cyl mode and not 8 cyl mode.
Old 05-04-2004, 10:17 AM
MeanWS6's Avatar
sorry - thats what I meant, loops are cut
Old 05-05-2004, 01:21 PM
marlowchris's Avatar
Do you solve thie problem? Please tell. I will be finishing my NXL install this weekend.
Old 05-05-2004, 04:20 PM
MeanWS6's Avatar
I have only sprayed it three times, before I posted here. Have not sprayed since - if something is wrong I dont want to blow it up. I am going to move down to the 120 jets this weekend, try it again. At any rate, I am getting a nitrous tune at Speed - they can work wonders
