Solenoid going bad?
Old 09-22-2013, 11:16 AM
white2kbird's Avatar
Default Solenoid going bad?
i have a 90mm N.O plate, been running a 74n/35f jets fine for 3 months through a NOS 16000 cheater noid. (Noid i bought used about a year ago) i've been increasing the shot in small increments from a 125 shot to where i am now, everything was running fine, good 12.2 afr's on the 74n jet. So the other day i decided to try a 76n with no other changes (watching my afr's real closely) and the car actually ran richer and slower obviously, afr's were in the 11.2ish through the hit, tried it again and same thing, so i said screw it and put back the 74n jet, went for a test drive and at first afr's were 11.3 then slowly climbed to 12.1-12.2 through the end of the run.. So i was thinking maybe its time to replace the cheater noid?.. anyone?
Old 09-22-2013, 08:05 PM
anyone?
Old 09-22-2013, 08:23 PM
dekan513's Avatar
4an line? if so thats ur problem . sometimes plates dont flow well after 150. i seen the same kit as urs on a 2010 camaro with a 200 shot make no more then it did with a 150 jet. put a nozzle on it and it picked right up.
Old 09-22-2013, 08:49 PM
hmmmm, on a Nitrous Outlet plate?
Old 09-22-2013, 11:34 PM
brandon6.0's Avatar
I was about to ask the same thing
Old 09-23-2013, 08:31 AM
87silverbullet's Avatar
What was your bottle pressure? Do you have a nitrous filter installed?
You only went up 2 jet sizes which isn't much is the reason I'm asking those 2 questions because there might be something restricting nitrous flow or pressure was down. A 76n jet will be fine on a 4 an line, unless the line is 25 feet long or something.
Old 09-23-2013, 10:28 AM
PaSteLaSo4U's Avatar
I have a question, is the filter an inline filter on the lines or a small mesh filter on the noid?
Old 09-23-2013, 10:38 AM
brandon@nitrousoutlet's Avatar
What bottle pressure? What Fuel Solenoid are you running? Fuel Pressure?
Old 09-23-2013, 11:01 AM
950-1000 bottle pressure, Nos cheater 16000 solenoid
Old 09-23-2013, 11:02 AM
Fuel noid cheater 16500
Old 09-23-2013, 11:13 AM
No inline filter
Old 09-26-2013, 04:01 PM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
4AN line is good up to 300 HP. I don't feel that would be the issue. Bottle pressure was good, no filter, so that wouldn't be the issue...(being clogged).. I'll have to go take a look at their solenoid, I'll see what I can come up with..
-Garrett
Old 09-26-2013, 04:19 PM
Being that that solenoid is 200hp, its probably somewhere around a .078 orifice... just off the top of my head, and if you are running a 76 jet in it, it might be close to maxing out that solenoid, which should be around 200 HP as stated, but you are only running a 125 shot? What fuel pressure is that jetting for?? According to my jetting, a 76 would be right around 200 HP worth of nitrous through that solenoid...
Thanks.
-Garrett
Old 09-26-2013, 04:29 PM
The 16000 is the Cheater solenoid and has an advertised orifice of .093. The -4 Main feed line is fine at your power levels so I cant see that being the issue. What does the fuel system in the car consist of?
Old 09-26-2013, 04:38 PM
[QUOTE=brandon@nitrousoutlet;17712422]The 16000 is the Cheater solenoid and has an advertised orifice of .093. QUOTE]
Thanks for letting me know that. Hopefully we can help get the OP's issue resolved.
-Garrett
Old 09-26-2013, 07:22 PM
Racetronix 255 Pump and upgrade wiring...
I tested the car again after replacing one of the plug wires that was kissing the LTH's and everything seems to be back to normal.
Old 09-27-2013, 08:59 AM
Glad you got the issue resolved!!
-Garrett
Old 09-27-2013, 04:34 PM
Good news. Let me know if you run into anything else.
Quick Reply: Solenoid going bad?
