Nitrous running rich
Alright guys, im to the roof with this issue im having. I run a 150 wet shot through a nitro dave 92 plate. however that 150 shot has never felt...well like a 150 shot. I run the 62/32 jets. my wideband reads way rich (10.0). It will read 10.6 for a split second but then right away go to 10.0
Whats the smallest fuel jet some of you have had to go to on a 150 shot?
Ive tried lowering the fuel jet, lowering the dedicated's pressure, and it still reads 10 ******* oh and doesn't feel like a 150 shot. I even swapped nitrous solenoids thinking i had a flow restriction. that didn't help.
Have you looked at your MAF readings to see if it's wigging out? Occasionally we have seen MAF voltage do funky things if it's close to a plate.
First check everything that NX has suggested above.
