Bottle mounting tips for C6
Old 10-17-2013, 10:05 AM
fastenough's Avatar
Default Bottle mounting tips for C6
I am trying to figure out a way to mount the bottle with a minimal amount of drilling in the trunk area. Ideas? I was figuring if I cut slits into the carpet I could just cover any holes back up, but I wanted to hear what others have done.
Thanks!
Old 10-17-2013, 10:15 AM
brandon@nitrousoutlet's Avatar
We have a mount for the C6 that you epoxy down and then mount your bottle bracket to: http://www.nitrousoutlet.com/97-04-c...er-side-1.html
Old 10-17-2013, 01:13 PM
87silverbullet's Avatar
I put a board under the carpet and mounted the the brackets to the board so I wouldn't have to drill holes in my vette.
Old 10-18-2013, 12:58 AM
03EBZ06's Avatar
I felt that going through the trunk recess and adding a plate on bottom side was the best/safest option. It concerns me that the bottle could fly forward in an accident if its not bolted down well. Of course, the floor is composite.
Note, NHRA requires "permanent mounting" and if in the compartment of vehicle, a vent tube to the outside. Permanent is not described, just no hose clamps or tie wraps.
You can always fill the holes w/grommets or something else if you remove the nitrous, but I would bolt that baby down.
Old 10-21-2013, 01:15 PM
fastenough's Avatar
I am interested to see what this looks like. Do you have any pictures?
Old 10-21-2013, 01:20 PM
fastenough's Avatar
How is the board secured in place? I saw others suggest this but no one seemed to elaborate on it.
Old 10-21-2013, 01:22 PM
fastenough's Avatar
Yeah, getting cracked in the head or replacing the windsheild would suck although I am not sure which one would be worse haha. I am not too concerned with the track regs as I don't go often.
The grommet/plug suggestion is a good one. Thanks.
Old 10-22-2013, 05:35 AM
Just take a sheet of plywood or mdf board that is 3/4 thick and is a 2 foot by 2 foot square and stick it under the carpet. The carpet will keep it from moving around and you mount the bottle brackets to it thru the carpet. Trust me, it won't move at all and no holes drilled into your vette.
Old 10-22-2013, 10:07 AM
03EBZ06's Avatar
lmao
Old 10-22-2013, 10:22 AM
Shoot me your email address and I can send you a picture!
Old 10-22-2013, 04:05 PM
fastenough's Avatar
Thanks, that makes more sense now. I will check it out.
Sent. Thanks!
Old 11-03-2013, 01:27 AM
Destroyer of Transmissions
1SlowHoe's Avatar
Can I get the same pictures? I want to mount the bottle in my C6, but still need room for the targa top. Looking for ideas.
MSgtB10@yahoo.com
Chris
Quick Reply: Bottle mounting tips for C6
