Bumped up my shot, getting a flashing SES light
Ok well this past weekend I put some fresh plugs in my car (BR7EF gapped at .032). I had TR-6s and was spraying a 100 shot without issues. Well on my test pass with the 150 shot my ses light starts flashing so I shut it down and it went away after a few seconds. My afr stayed good at 11.9 the entire time while spraying so I'm not sure what's going on. Has anyone heard of this or experienced it?
Plugged in a code reader yesterday. No code was stored. The plug wires are stock replacements and they appear to be in good condition. Haven't had a chance to pull plugs yet, will probably get to that today after work. The only thing that crossed my mind was upon reinstallation of the wires the #2 cyl wire didn't snap when I plugged it into the coil pack. Its all the way on. Just didn't snap....
Probably the plug wire, or maybe cracked the porcelain on one during install.
I doubt that it's anything serious being as you had 4 degrees timing pulled and running the right plugs.
Update: well I finally got around to checking the plugs and they looked fine. Made sure all the wires were good n' tight. Went out to the track and ran it on the 150 shot and she ran flawlessly. Not sure if it was a fluke or what but it ran great.
