Stock block 383 350 shot
Old 11-19-2013, 08:09 PM
0-60's Avatar
Default Stock block 383 350 shot
I got a stock 5.7 block bored 3.905
215s from TEA (243s)
Port matched super Vic with spraybar setup
Fast 4150
Custom ground camshaft
Callie's magnum XL 4.00 crankshaft
Callie's compstars
Wiseco pistons
Tool steel pins so on and so forth
Car weighs 3100 with me in it (2000 camaro)
Th350 with brake
12 bolt with 373s
28s
Any suggestions....?
Ideas what it's gonna do...?
Things I need to watch and look for...?
Something that I'm over looking...?
How hard can I spray it..? Any input on me spraying it 400-500?
I enjoy all types of criticism and input thanks.
Old 11-20-2013, 12:00 AM
2 Stroke Racer's Avatar
What's it gonna do? Is that what your asking?
Ok.... I'll guess. Spin? Blow head gasket? Burn a hole in a piston?
Maybe run you personal best?? Flip over?
What do you want people to say here?
Old 11-20-2013, 03:55 AM
Blackbob's Avatar
All of the above ? ^ lol.
Old 11-20-2013, 10:40 AM
brandon@nitrousoutlet's Avatar
Do you have a dedicated fuel system to feed that size shot?
Old 11-20-2013, 07:16 PM
0-60's Avatar
Brandon yes I do. I'm gonna feed one of your pucks with a dedicated system with a 255 that I plan on setting up in my hatch area. I have a 465 in tank and I'm gonna pull a small kit off it into one of your new 4150 plates. Is what I have planned.. What I'm asking is the motor capable of handling these types of things.
Would you think the th350 is gonna break. Will the car need progressive controller what size tire do you suggest. If it all works out what's something like that capable of doing.. Just some sort of input not bullshit
Old 11-20-2013, 07:17 PM
0-60's Avatar
Are the heads to small...?
Old 11-21-2013, 12:13 AM
Stumped1215's Avatar
What are the cam specs?
Stock casting heads are not great for that much nitrous.
I'd bet the th350 will break first pass. It needs a 400 or better yet a glide.
Have you ever used nitrous and do you know how to read plugs?
Thats a start
Old 11-21-2013, 06:55 PM
87silverbullet's Avatar
Thats a start
How is a 350 shot bad for stock castings? Guys have been hitting many motors on here with that much with stock castings with no issues.
Th350's are stronger than you think. No need for a glide or heavy *** 400 yet.
Old 11-21-2013, 07:00 PM
Zmg00camaross's Avatar
^^^ agreed. Seen several 700 hp 3800 lbs car run on th350.
Old 11-21-2013, 08:04 PM
0-60's Avatar
I'm hoping it makes close to 500 on the motor it's supposed to be somewhere around 12.1 compression... I want it to make mid to upper 800 range. On a perfect day the car should break in the 8s.
FYI I have not had a cam cut for it.. I'm waiting to get everything all in order to havey converter and cam made pretty much at the same time.
Old 11-21-2013, 08:05 PM
0-60's Avatar
I was thinking maybe PAT G makes the specs and some sort of Neil chance converter
Old 11-21-2013, 08:07 PM
0-60's Avatar
And yes know a couple things about nitrous I sprayed my factory 180k mile stock block stock head stock intake 5.7 335 on 2 kits with a 255 pulling them both from the fuel rail. And never made a single pass with that setup
Old 11-21-2013, 09:17 PM
JRracing's Avatar
Well I have a 13:1 383 ci 5.7 block with afr's and the cam was made to be decent at both motor and spray. So I'm giving up a little on both. My cam is a 248/258 on a 112+2.
My motor builder said with the pistons I have he would not recomend going past 200-250 shot. Now that is with Diamond pistons that are light duty nitrous app.
But on a 200 shot coming out very soft I ran a 8.97@150 at 2725lbs.
I would run a set of the new 275 radial pro's from MT. But your car needs to be setup well for them to work. Or just get a set of 28x10.5 slicks.
My car has cut a 1.25 60' on the radial pro's.
Old 11-22-2013, 09:07 AM
Without seeing the build sheet on the motor I don't know what it will take nitrous wise. I'm sure 200 would be fine. We had a customer go 8's on a stock bottom end 5.7 with stock 853 casting heads if that tells you anything. Your tune will be very important at those horsepower levels. Are you familiar with reading plugs?
Old 11-22-2013, 09:10 AM
0-60's Avatar
Yes Brandon I'm familiar
Old 11-22-2013, 09:53 AM
Good deal. What car is this setup going in?
Old 11-22-2013, 04:24 PM
Bader!!!
Old 11-22-2013, 08:17 PM
0-60's Avatar
In my 2000 camaro.. And as to what I'm willing to do to lighten it up.. For all I care I'll take a cutting torch to it.. Sky's the limit.. It's just gonna be something I street race more than anything
Old 11-23-2013, 09:03 AM
You can do a good bit to lighten the car up. My car weighed 3425 w/o driver with slicks and skinnies. It still has all the creature comforts, 12 bolt, and a th350. Stereo and sub in the rear with 1/2 tank of gas and nitrous bottle. Stock k member too. Its a 2001 SS.
My buddy's 99 SS is somewhere around 3100 and he still has alot left to do. he got rid of the exhaust and put a 3 inch bullet on the y pipe. Removed the A/C. Back seat delete, k member and arms, rear speakers removed, lightweight carpet, and a bunch of things I can't remember.
Quick Reply: Stock block 383 350 shot
