tuned my car 200 shot stock long block video
something was happening at about 6000 rpm right at the end of the video, could not figure it out.. its 133,000 mile stock long block car, spraying 200
Looks like it hit pretty hard. Couple questions to help determine what that was around 6k.Do you have a copy of the dyno graph you can post here? How about some data logs? What type of system? Jet spread? Plug? Plug gap? Timing?What are you using to pull timing? Help me help you
possibly window switch might be acting up..... other thing that can cause surging is running out of bottle pressure (bottle running out maybe?)... but sounds like you hit limiter.... it wasn't like a regular limiter cut off since it cuts fuel, but you have fuel that will still come in from the nitrous kit.....
