Best Nitrous Tuner in Midwest???
Old 12-08-2013, 07:56 PM
Flashy's Avatar
Default Best Nitrous Tuner in Midwest???
I'm looking to add a Nitrous Outlet plate setup to my LS1 GTO MN6; Currently car made 420whp with: K&N Intake, PRC Stage 2.5 LS6 Heads, TSP TorquerV2 cam, Kooks 1 7/8 Headers and Off Road Pipes, SLP LM2 Exhaust.
Since then I've added:
FAST 102mm Intake Manifold
FAST 102mm Throttle Body
DW65c Fuel Pump
(Have not gotten larger injectors yet....looking at something around 40 lb/hr.)
I'd like to hit it with a 150 wet plate from Nitrous Outlet; Car is tuned with HPTuners currently.
Looking for suggestions and/or experiences with Midwest tuners on nitrous....I'm trying to keep this stock cube/stock internal motor from blowing up.
Old 12-09-2013, 08:36 AM
LsxBird's Avatar
I had Straightline Performance tune my trans am. made 520/550 on there mustang dyno with bolt ons and a small 212 221 on a 150 shot. had them set up my suspension also dead hook with 6100 rpm clutch dumps. Good experience there, i will continue to bring my business to them.
Old 12-09-2013, 09:38 AM
brandon@nitrousoutlet's Avatar
Where exactly are you located?
Old 12-09-2013, 05:21 PM
Flashy's Avatar
Located in Milwaukee,WI.
Old 12-10-2013, 10:29 AM
03EBZ06's Avatar
you are!!!!!! Learn to tune it yourself AT the track NOT on a dyno.
Old 12-10-2013, 01:21 PM
87silverbullet's Avatar
^^^What he said. CSICKS on here is doing that right now. He is making a pass and pulling his plugs and posting on here for us to see and we tell him what direction to take it and goes from there.
Old 12-10-2013, 03:06 PM
BigEd_72455's Avatar
Best thing to remember when doing ANY tuning of any kind, if it does not feel right or starts to act a bit goofy, TURN IT OFF.. Keep your foot out of it until you can come back and check things out.
Old 12-11-2013, 09:12 PM
Flashy's Avatar
I'd like to get it close to dialed in on the dyno and then will monitor it and make fine tuning adjustments while learning more and more.
Old 12-12-2013, 08:49 AM
If you're not experienced, a dyno will throw you off more than you know
Quick Reply: Best Nitrous Tuner in Midwest???
