Best Nitrous kit for me? NXL or just the NX wet system
Im want to order a nitrous kit. And I have been waiting for that new direct port kit that NX is supposed to be coming out with. I just thought that it would be a really clean kit. No selinoids to mount or lines to run. And direct port gets even distribution to all the chambers. But on the other hand I only want to use a 100 shot. So that kit will probably just be over kill for me. And its about $800 more than the regular NX wet kit. What would you guys do?
thanks
sean
thanks
sean
!Dial-up Director
Re: Best Nitrous kit for me? NXL or just the NX wet system
A regular NX wet kit will do fine, or you could opt for the NX MAF kit like I did. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Justin
Justin
is that the dry kit? If so then I would need larger injectors. And you cant tune a dry kit can you? <img border="0" alt="[gruffy cottonball]" title="" src="graemlins/gr_gruffy.gif" />
!Dial-up Director
Jessie, the kit does come with both MAF ends. It's available as a whole wet kit or as a MAF upgrade to the standard wet kit. Any NX supplier can hook you up. You could start with http://www.nitrodaves.com/outlet/ or http://www.tbryne.com for sites that have the kit on their web catalog.
Jsears8, what kind of shot are you going to run... 150?? I know Ruf SS is set up for a 100 shot on his 382. I'm going dual stage starting with a 100 out of the hole and a bonus 75 down the track? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I haven't noticed anyone else using a dual with the MAF kit yet.
Rick
<small>[ February 23, 2003, 11:03 PM: Message edited by: 2001-WS6 ]</small>
Rick
I like the Venom computerized system. VCN-1000 is considered a dry set up. it measures the O2 sensors Rich/Lean and disables the system if it leans out. It adds fuel with the injectors negative side wire. pretty kewl setup.
