ls3 vette
Old 01-27-2014, 08:44 AM
dekan513's Avatar
Default ls3 vette
i made the switch from a ls3 camaro m6 to a 08 ls3 vette a6 . i had cam intake full exhaust on the camaro with a hsw plate on a progressed 150 shot. lnc2000 pulling 4* . my question is on a vette running the same setup will i need more fuel pump. i didnt on my camaro . never had it on the dyno with nitrous but it made 481/443 on motor. next question is im thinking about going to a spray bar or something a little cleaner or should i just stick to a plate. which is better and safer for equal distribution. im gonna upgrade my plate soon .nitrous outlet will be the company to do it as they have helped me with any question ive had over that last year or so . i have never bought a product off them but they go above and beyond to help a guy in need. that earns my respect.
Old 01-27-2014, 09:25 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
How much are you looking to spray? A plate still makes for a pretty clean install, we have a nice bracket setup for the solenoids, I'm sure NO does as well. If you are going to be spraying 250 or under, I would just put a plate on.
-Garrett
Old 01-27-2014, 09:35 AM
dekan513's Avatar
ty for the input lookin to spray a 150 hit for a while then later when i get a fuel cell for some better gas do a 200 hit. but that will be the max . unless i later do a engine build
Old 01-27-2014, 02:57 PM
Cool, sounds like a plate system might be the way to go for you then!
-Garrett
Old 01-28-2014, 09:48 AM
brandon@nitrousoutlet's Avatar
Our hardlined plate system makes for a very clean setup and will leave you with plenty of room to grow later on down the road. Is your vette fairly stock? Don't forget a window switch with it being 6 speed.
Old 01-28-2014, 10:30 AM
dekan513's Avatar
vettes a a6 , i got a nos launcher and lnc2000 tho from my camaro that i will be using. atm its just has headers but wont for long. will be vararam, .64x .61x lift cam 111 lobe sep. 3600 stall , lg headers no cats . with the nitrous of coarse . i just wonder if ill need more fuel pump.
ya i believe ill stick with a plate . got a friend gonna buy my current plate hsw plate.
Old 01-28-2014, 10:58 AM
Oops I misread. As of right now you should be fine on the stock pump. Once you get up there with the mod's+nitrous I'd keep an eye on fuel pressure.
Old 01-28-2014, 03:29 PM
dekan513's Avatar
k thats what i was thinking. do u guys sell just the plate as a friend just want to buy my plate off me.
gonna be gonig for some records for the ls3 here around the end of the year. gonna play aget things setup thur spring and summer and hopefully everything goes right and i can push this block for all its got.
Old 01-28-2014, 05:00 PM
We sure do! Let me know if i can help you with that record.
Old 01-29-2014, 09:54 AM
dekan513's Avatar
oh i will. lol
Old 01-29-2014, 11:32 AM
z28SSilvest's Avatar
How did the ls3 Camaro on nitrous work out for you? I plan on spraying mine one day lol
Quick Reply: ls3 vette
