4an or 6an feed line question
I see the Nitrous Outlet 78mm LS1 plate kit comes with a 4an feed line, while the Nitrous Express 78mm LS1 plate kit comes with a 6an feed line. I don't want this thread to turn into a pissing contest between the two companies; I just want to know if there is a major difference between a 4an feed line and a 6an feed line? How much HP can a 4an feed line support and how much can a 6an feed line support?
I have the nitrous outlet kit on our C5 so of course it has the 4an line. I'm not an expert, and have been doing a lot of research lately to learn about it all, but my understanding is that I can do 250 with the 4an and past that, up to 400, can be accomplished by just changing to 6an. If someone knows more and can correct me please feel free.
Scott
Scott
Thanks Brandon. My stock pistons/rods won't see more than a 200 shot anyway, so looks like a 4an is fine for me. I like the way your kit has the noids on a hardline (just makes for a cleaner look in my opinion). Plus, sounds like upgrading to a 6an line isn't a big deal.
Brandon, on the 78mm LS1 kit, how much are the noids good for?
Also be sure to upgrade your line from the solenoid to the plate from a -3 to a -4 when going spraying 225+
One end is a -4 that connects to the solenoid and the other end is a -3 that connects to the plate. But the ID of the line is a -4.
I already a bunch of the parts. Bottle/mount, heater, remote opener, Nitrous Outlet 2 stage 90mm plate, -4AN feed line. All I need yet are the solenoids, switch panel, TPS/window switch.
All of my fuel lines are braided stainless and will eventually convert all the other hoses to braided stainless....will probably go with braided stainless lines just to match up.
Gonna run 1 side of the plate for nitrous/fuel and the other side for meth/meth
