relay question (wire colors)
Here is the nitrous outlet relay I'm using:
I have a wiring diagram showing me what goes where but I just want to make sure I'm using the correct color wires. There is a schematic on the side of the relay but I'm not sure I understand it and want to be right when I start wiring our system this week.
Green wire in the front: #30 - to the battery
Black wire on the back: #87 - to the solenoids
Red wire on the left: #86 - to the NOS WOT controller
White wire on the right: #85 - ground
Thanks!
Scott
Thanks!
Scott
Ls1tech & Truck Sponsor
Thanks!
Scott
Thanks!
Scott
Black goes to 12v battery
Red goes to WOT Switch, then on to master arming switch.
White is ground.
This is how ours are setup for our systems. If you are using a controller it does tap into the red wire.
Let me know if you have anymore questions.
Thanks,
Garrett
