need dry kit info... fbody ls1
Old 02-25-2014, 06:19 PM
dustind6327's Avatar
Question need dry kit info... fbody ls1
im new to the fbody world and have some questions?????
im looking at a dry kit for my car..these r the mods i have for my car
full true dual exhaust, walbro 255 pump
asp crank underdrive pulley asp alternoty pulley
slp ported oil pump
lunati dual roller timing chain
lunati 232/238 113 cam
92 fast intake and 92 throttle body
spec 2+ clutch
410 gears
`1. which kit would be best for the set up i have money is not an issue better be safe than sorry??
2 what shot should i use with my set up that i already have and will stock injectors still be fine?
3 i want i kit i can hide was looking at the hidden halo kit and info on that kit
thats all i can think of as now but if someone could help me on this would be great
Old 02-25-2014, 07:50 PM
HCI2000SS's Avatar
How much you wanna spray? That might slightly determine you injectory duty lol
Old 02-25-2014, 08:05 PM
I'm thinking 50-100 shot but whatever would be safe if I have to upgrade injectors that won't be a problem either just trying to get all cards on table before I start shopping. buy all at once I. hate waiting for one simple thing
Old 02-25-2014, 08:07 PM
HCI2000SS's Avatar
Well the way I would look at it is anything less than a 100 shot is a waste of time IMO, so with that in mind you probably will need to upgrade the injectors with a dry kit
Old 02-25-2014, 08:16 PM
Ok that cool now the question is which is a good reliable kit??
Old 02-25-2014, 08:20 PM
HCI2000SS's Avatar
The only dry kit I ever used was on my Mustang and it was just a basic NOS kit. Not really sure what the LS guys are usuing in the way of dry kits these days, but I have a few friends who have had great success with the NOS dry kits as well
Old 02-26-2014, 08:15 AM
Rise of the Phoenix's Avatar
The Nitrous Outlet Halo Spray Bar would be good for you.
http://www.ws6project.com/user_stor/...-10lb-bottle-/
Old 02-26-2014, 08:35 AM
That's what I have kept my eye on but trying to get other people preference on which kit should get or is better or worse ect ect
Old 02-26-2014, 08:43 AM
The good thing about the one I listed above is that it would be very easy to hide, which it sounds like you want to do. Nitrous distribution would be really good too with the Halo Bar, as opposed to a single or dual nozzle.
Not sure why it double posted though.
Old 02-26-2014, 09:24 AM
I don't mind if it was visible but after I did research I saw lot of people wants to hide it.. Saw on pic where he ran it under the entire air box and used a 90 up under the lid also had the solenoids under too but I believe I'm sold on the halo unless somthing else comes up but I wanna run a 100shot will stock injectors hold up or do I need to upgrade
Old 02-26-2014, 09:32 AM
luigiandme's Avatar
Here's the best advice for you.
Do a wet shot.
Old 02-26-2014, 01:25 PM
I don't see anyway that the stock fuel injectors will work. I'm damn surprised they worked with your NA setup. I have an NA setup similar to yours and there is no way my stock injectors would have worked.
Old 02-26-2014, 01:54 PM
i just bought the car how it sits and i was curious about that also guy said it was ok but im putting 42# in it i dont like being close to the max on injectors.. i like having plenty of room for fuel..
Old 02-26-2014, 02:00 PM
Very smart on your part. Not knowing what duty cycle the injectors are at is like playing with fire. With those and the fuel pump you have, you should be golden.
Old 02-26-2014, 02:07 PM
speaking of injectors my tuner told me about this company "Deatschwerks" said those r really good have u heard of them>?
Old 02-26-2014, 02:11 PM
Yeah, heard of them, but don't know much about them. I run Accel 44lb/hr injectors and love them. I know a lot run Ford green tops and Bosch is a very well known and popular brand on here.
Old 02-26-2014, 02:17 PM
im new to the fbodys but the reason he likes them cause it comes with all the proper certs for each injector shows all the pounds it was tested o... flow and ect ect other than others all it comes with is the receipt..lol
Old 02-26-2014, 02:53 PM
brandon@nitrousoutlet's Avatar
Those guys make good parts!
Old 02-26-2014, 03:06 PM
Is Deatschwerks the company that can re-size injectors?
Quick Reply: need dry kit info... fbody ls1
