Pusher system/NANO questions
From my perspective, to use a pusher system such as NANO you must have at least a 3-port valve. Valve1 - outlet, Valve2 - NANO inlet, Valve3 - Blowdown. Correct?
All 3 of these ports share the same path to the bottle through the tube, correct?
If you are using a pusher system, how does the contents of the bottle come up through the tube if the same tube is delivering pressure into the bottle from the pusher system??
Thanks Canadian! Just as I got your reply I wandered onto this threadhttps://ls1tech.com/forums/nitrous-o...ress-come.html See post #5 in the thread
The reason I was even asking about all this is that I would like to add NANO to my existing setup. I have a 12# NX carbon fiber bottle with a standard valve. Also, I run a NX bottle opener. I would like to switch the valve to at least a 3 port but I must be able to use the opener. Any suggestions?
Thanks for the great explanation!
picture of valve? I just threw out a 2005 Standard valve by Nitrous Express yesterday. It had 4 ports, 2 plugged by 1/8" NPT plugs.
I think that valve would have worked well w/NANO because it was free flowing when I blew through the push port.
You should just buy my NANO Valve setup! (pic in other thread). I'll throw in
the valve I threw out at no charge. Note, I bent the siphon tube when I trashed it but it could probably be straightened pretty easy.
$50 for combo?
edit/update: found valve. You will have to replace the tube.
$50 for combo?
