BR7EF how are they N/A?
Old 03-31-2014, 04:29 PM
stevecritt's Avatar
Default BR7EF how are they N/A?
Seeing as my car is primarily N/A, how are these plugs? Will I notice any power difference? I actually have both the Tr6 and Br7ef plugs right now. I'm just trying to figure out which ones to install before I put my motor back in.
I have 200hp jets installed for my nitrous plate.
Thanks.
Old 03-31-2014, 04:33 PM
DietCoke's Avatar
wont notice much of a difference, if any. projected plugs idle a little better
Old 03-31-2014, 04:39 PM
stevecritt's Avatar
So I should Def stick with the BR7? and let her rip?
Old 03-31-2014, 04:51 PM
brandon@nitrousoutlet's Avatar
On a 200 shot yes the BR7's are definitely the better choice over TR6's. As said above you wont see much difference between the two while on motor.
Old 03-31-2014, 07:14 PM
HCI2000SS's Avatar
BR7's here gapped at .030, and no difference whatsoever running n/a. It's all in the tune
Old 04-02-2014, 02:16 AM
JDEP162's Avatar
same here gapped at .032 ran a 13.6 on them NA and no noticable differnce at all.
Old 04-02-2014, 07:44 AM
Blackbob's Avatar
.033 BR7 and like others said it's fine on motor and I've done well over 15k that way.
Old 04-02-2014, 09:21 AM
Old School Heavy
speedtigger's Avatar
If your tune is clean, the plugs will stay clean. Mine stay very clean and I have never seen any difference in my times at the track N/A.
Old 04-04-2014, 10:14 PM
redgto4u's Avatar
What compression ratio? Would a BR8 be a better choice for a max effort NA motor and a 200 shot on top?
Old 04-05-2014, 12:56 PM
Detoxx03's Avatar
They will be fine if gapped correctly and the tune is good. I ran them 8's and 9's on a daily before with no issues.
Old 04-07-2014, 09:53 AM
Personally, I'd go with the 8's on that setup. They will drive fine. His question was should he go from TR6's to BR7's in which case the BR7 is the better of the 2 but ideally the B8EFS is the way to go.
Old 04-20-2014, 08:51 AM
ls2 bait's Avatar
I have 8's in mine and it drives just fine. I only spray it to clean the plugs
Quick Reply: BR7EF how are they N/A?
