How does running lean cause Nitrous Backfire?
Hi, first post here: I know this probably has been covered before, but after doing some research, I'm still kinda iffy on this subject. I've read things about the fuel falling out of the nitrous/air mixture in wet systems and puddling in the intake manifold, running rich, cranking the motor over after having nitrous being injected, backfiring when hitting redline, which makes sense. However, I've read things saying running lean could cause a backfire. Could someone explain how running lean could cause a nitrous backfire? Thanks in advance, Kyle
The plug begins glowing constantly from being so hot. Then it preignites the cylinder before the compression stroke is over. Basically it lights the cylinder to early and tries to drive the piston downwards while it's traveling upwards. This is what beats the bearings out of them.
Old School Heavy
There are a couple things that come to mind for me in that scenario. But, this is my best guess:
Very lean mixtures are very easy to ignite and burn much faster. Since the intake valve is open at the same time as the exhaust valve for a very small amount of time just before the intake stroke, a very lean fuel mixture's flame front could actually travel fast enough to outpace the intake charge velocity and travel back into the intake tract igniting the over-lean air fuel charge in the intake. With nitrous in the equation, this would be exaggerated.
