Can the timing tuner be used with a maximizer to retard nitrous?????
The maximizer has the ability to control a retard unit and I was curious if the timing tuner could be used in conjunction with it to retard on the bottle. I would only want to use the retard function of the tuner not the window switch or advance.
Thanks in advance.
Tom Palermo
Thanks in advance.
Tom Palermo
Thanks in advance.
Tom Palermo
Thanks in advance.
Tom Palermo
Good luck!
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Originally Posted by LS1 Power Plant
Out of the box the timing tuner will not work with a progressive controller.
I asked this same question here before I noticed this one...oops
https://ls1tech.com/forums/nitrous-oxide/172818-nos-progressive-controller-ramcharger-s-timing-tuner.html
Originally Posted by Chingon
So you contacted the maker of your timing tuner to make it work with your progressive controller? What happened?
https://ls1tech.com/forums/showthread.php?t=172818
