Dual stage bottle requirement
Old 05-17-2004, 04:06 AM
PREDATOR-Z's Avatar
Cool Dual stage bottle requirement
Can a 15 pounder supply a dual stage dry/wet?
If so what parts are required to run 2 N2O lines out of 1 bottle?
Plan is to run Stage 1 dry (75rwhp shot) + stage 2 wet (75 rwhp shot); for a total of 150 rwhp dry/wet
Old 05-17-2004, 07:24 AM
The Bull
DERTY's Avatar
You can run a dual stage out of a 10 as well. You just use a Y connector in the line to split it.
Old 05-17-2004, 09:53 AM
Ben R's Avatar
Why do you want 2 stages? I might be able to justify that if you had an M6 and were racing on Nitto's or something, but your sig says you're an A4 on M/T ET Streets. You should be able to spray that 150 shot right out of the hole with that setup.
Old 05-17-2004, 11:32 AM
PREDATOR-Z's Avatar
With my current set up yes.
But over the next 3 months, my motor is gonna go through serious steriod mutations. I would say in the neighbourhood of 420 rwhp N/A. with a SS 4000. So launch will be a bit more demanding. My goal is 600 rwhp on juice (While limiting the juice as much as possible.)
I need to be in solid 10's by September.
Old 05-17-2004, 11:39 AM
The Bull
DERTY's Avatar
Fire out of the hole then if it's a street/strip car and you're going for track times. The dual stage wouldn't even be worth it IMO.
Old 05-17-2004, 01:59 PM
PREDATOR-Z's Avatar
So what you're saying, I'll be better off converting my NOS to wet and shoot 150 straight up?
Old 05-17-2004, 03:33 PM
The Bull
DERTY's Avatar
Pretty much. There are a lot of cars that are completely capable of running a setup like this and getting into the 10's. You don't need two stages at all, you'll be quite surprised.
Old 05-17-2004, 10:09 PM
Draco's Avatar
I'm running 2 stages off a 10lb bottle, with a y-fitting near the solenoids. My only problem is that I have to refill so often lol.
Old 05-17-2004, 10:40 PM
pmbmax's Avatar
I spray my car with a 250 all the time buy a good torque arm and struits relocation brackets. get the tires hot and hold on i have pull low 1.4 short times all the time i run hoosier QTpros. and last week run 10.50s
Old 05-17-2004, 10:59 PM
Robert56's Avatar
I like the dual stage thing, much easyer on equipment (but maybe not fast enough?). But if you stay single stage why not go to 36lb injectors and leave your current set-up the same.
Old 05-18-2004, 04:19 AM
PREDATOR-Z's Avatar
That is what I'll probably start with.
30 pounders FORD (Flow like 36lbs with our high pressure systems), a walbro/or Holley 255 intank and I ordered the NX conversion kit.
I will do that before H/C (224/228, 0.5xx/0.5xx 113lsa XE-R), with 5.3's stage II race.
