Nitrous pressure drop - How much do you see when you spray?
Old 05-19-2004, 03:54 PM
MeanWS6's Avatar
Default Nitrous pressure drop - How much do you see when you spray?
Providing you have a nitrous pressure gauge inside the car, how much of a pressure drop do you guys see when you spray?
(this post is in relation to my NXL saga where I am getting over a 400PSI drop while spraying )
thanks for everyones help
Old 05-19-2004, 04:46 PM
GM Muscle's Avatar
Your spraying a 180 shot right? With a 15lbs bottle at about 1000psi (TNT 150) I havn't seen any more that 100psi drop during a good run. Have only gotten to play with the 150 shot on the street but I usaully run from 40 mph to about 100 mph or so. I do remember reading your other posts so I assume that you have double checked all the fittings after the N2O noids?
Old 05-19-2004, 04:56 PM
MeanWS6's Avatar
yea, 180shot, 15lb bottle, checked and double checked all fittings and jets, starting pressure is 1050psi, tried diff bottles and angles, etc.
Old 05-19-2004, 06:13 PM
B18B1LS1's Avatar
What kind of temps are you running to get to 1050psi? Are you sure the bottles are good and full? I know it's "bad" but it is easier to maintain pressure with a slightly overfilled bottle. I usually don't get any more than a 200 psi drop and even that is a little excessive. Granted that is only with a 150 shot though.
Jeffrey
Old 05-20-2004, 02:50 PM
MeanWS6's Avatar
Jeffrey
I do my own fills, yea I usually still an extra pound in them
Maybe this NXL kit was a complete waste of time and money.
Old 05-20-2004, 02:54 PM
Nitro Dave's Nitrous Outlet's Avatar
I Have never seen a pressure drop like that.Are you sure you have3 a good full bottle with no air in it.
Dont get to fustated im sure its something that is just going to turn out simple.Shot me a PM with all the info from beginning to end.Ill see if I can help you out.
Dave
Old 05-20-2004, 03:25 PM
MeanWS6's Avatar
dave - you are the man -PM sent
Quick Reply: Nitrous pressure drop - How much do you see when you spray?
