How much does a .001 change in fuel jet change actual air fuel ratio?
Does anyone know what the correlation is here?
At the track with a 150 shot (using a 62N and a 33F) I am running mid to high 10 AFR up top. I want to get some jets coming to try to lean this out a bit and wonder what I need to order. Is it worth trying a 32 jet or should I get a 31? I just hate to buy a bunch of extra jets that I might never use if I do not have to.
Ls1tech & Truck Sponsor
-Garrett
OK I would like to know the answer to this as well.
I have a shark nozzle kit and have done the upgrade so it will spray a bigger shot and this is what I was told
"shark nozzel upgrade"
Uses the same psi you currently run "stock".
The jettings are as follows.
N20/Fuel
150HP 62 34
175HP 73 39
200HP 78 40
225HP 82 42
250HP 88 46
See between the 175/200 only 1jet size difference "fuel" & only 2 different between 200/225. So what has been said in this thread is that I can run a 78/38 for a 200hp shot or a 78/41 and it will be about the same. Is this true?
N20/Fuel
150HP 62 34
175HP 73 39
200HP 78 40
225HP 82 42
250HP 88 46
N20/Fuel
150HP 62 34
175HP 73 39
200HP 78 40
225HP 82 42
250HP 88 46
N20/Fuel
150HP 62 34
175HP 73 39
200HP 78 40
225HP 82 42
250HP 88 46
Yes you can, going one way or the other a jet size or two will either lean or richen the car on nitrous.
-Garrett
N20/Fuel
150HP 62 34
175HP 73 39
200HP 78 40
225HP 82 42
250HP 88 46
N20/Fuel
150HP 62 34
175HP 73 39
200HP 78 40
225HP 82 42
250HP 88 46
