LNC-2000 & FJO Nitrous Controller
I have these two items and i plan to wire them in this weekend. im using a Dynotune wet plate system. I dont have a line lock and im not planning to use the 2 step. Every diagram i have found list one or the other if you could provide any assistance wiring this i'd greatly appreciate it. thanks
LS1Tech Sponsor
LNC-2000 with FJO
Since it doesn't appear that the FJO controller has a an output capability (timer out etc.) the only options that I can think of are:
Be interested to know if anyone else has ideas on how else to do this.
- Activate the LNC-2000 timing retard (orange wire) with your nitrous arming switch. This will mean it will be pulling timing before the nitrous becomes active.
- Activate the LNC-2000 timing retard (orange wire) with one of the two stages of nitrous, like we show for the MicroEDGE+ on page 25 of the LNC-2000 instructions. To do this you would have the one stage not be progressive but just be used as an activation control for the LNC-2000 and have the other stage actually control your nitrous.
Would it work if I connected the orange wire to the solenoid itself when it fires it pulls timing then or will that not work? Also curious if the pulsing from the progressor will affect the voltage needed to pull the timing?
LNC timing retard activation
You can't connect the activation wire to the solenoid itself if you are using a progressive controller because the solenoid is being pulsed on and off very quickly (usually in the range of 10 to 40 times a second). The timing retard activation wire on the LNC-2000 has to be a conventional constant +12vdc signal. If it pulses on and off the timing retard won't operate correctly (or at all).
Thats what i was wondering. Thanks Guys i think i have a understanding of this a little better now..
